주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
iPhone no sound, black screen, no vibration when plugged in
I dropped my iPhone and it has a black screen, doesn't make any sound, doesn't vibrate when plugged into the charger. But when i plug it into iTunes it recognizes my phone and it shows that my phone can still charge. DO you guys thin my screen and digitizer is broken or my logic board. Like when i plus it into my computer, my computer makes a sound instead of the iphone, and when i hold power and home when plugged into the comp for 10 sec, it makes another sound.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
So i woke in the morning to found out that my iphone x that's on the charger won't turn on , i tried pressing the power button it won't turn on , i tap on the screen it won't work. then i following the force resting steps and it's didn't work and i plug it up to the computer and the iTunes doesn't show up ,what should i do now ?
댓글 달기
답변 5개
가장 유용한 답변
might be stuck in recovery
try using the mute switch to see if it vibrates when switching.
if it vibrates then its a screen issue. if not then its in recovery.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
it doesn't vibrate
does itunes say its in recovery or does it say the entire phone info like normal? if its normal then the phone might be disabled or some how the vib is not working.
how can i exit on the recovery mode?
recovery mode will automatically restart to normal operation after period of time reboot on its own. but you can always hold power and home to do a normal restart that will start a normal boot sequence.
댓글 달기
I have the same problem!
after a very very small stroke the screen turned black, no sound, no vibration. but itunes recognizes it but I can not access it because I can not put the pin and make a backup. do you think you disconnected the connector? the technician told me the faulty display. But the vibration and the sound that do not work? are all connected to the screen???!
thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Hi I have iPhone 7 plus as same problem. Did you solve that problem?
Please tell me how.
Thank you so much!
I am wondering the same thing. I think usually if the screen is bad the vibrator and sound still work. I am very confused on mine. No drops. No water damage.
Hi! How did you manage to solve it? Have the same problem here too
Have the same problem, changed the whole motherboard and nothing, I don't know what else I can do, hopefully someone has an answer to this problem
댓글 달기
Good morning, how did you solve the problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi! Have you solved the problem? Have this too
댓글 달기
I have had the same problem after replacing the battery on iPhone SE. I thought the new battery was bad, but when I plug it in iTunes starts backing up and syncing like normal and show the battery charging.
I have done a lot of iPhone repairs and I cannot figure out if I did something wrong or if I just had really bad timing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How did you solve it? Have this problem too
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I didn’t solve it. I had to scrap the phone. Replacing the screen didn’t do anything.
댓글 달기
귀하의 답변을 추가하세요
muning 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 32
전체 시간: 3,550
