Change the t100 internal hard drive?
The biggest limit to the Asus t100 is its internal hard drive, which in my case is only 32 GB and this means I am limited from day one. So I was thinking, can I open the tablet, remove its internal hard drive, and replace it with a fast 128 GB MicroSD instead? I'm no technician but I don't see why that's not a great idea ;)!
P.S. Why not multiple MicroSDs?? ;D
좋은 질문 입니까?
댓글 1개
I also have that issue. The main problem is that you can't update the OS when the internal (screen) HD is full and it does not appear that you can boot from the micro SD slot in the screen portion either which would make it great since you can get a bigger micro SD card than is internal in the screen.
Lou 의
