주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mac mini 제품군은 2005년 1월에 처음 소개되었습니다.
Stickies application will not open.
When I click on the stickies icon in the doc or in the applications folder no stickies will appear. I get the stickies bar across the top but no stickies.
Sandy
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
선택된 해법
On the menu bar at the top navigate to Window and confirm that there are any active stickies. There should be a list of all open stickies there, click one to pull it to the front. If there are no stickies listed, then all Stickies have been closed. Make a new sticky by going File>New (+N).
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
It's working
if you see the menu bar change, and the throbber in the the Dock. Also check under Apple icon->Force Quit if it's frozen it will be noted.
• To close this note, click the close button.
• To collapse this note, double click the title bar.
• Your current notes appear when you open Stickies
If you have no new or current notes there's nothing to show.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you so much. You rock!
댓글 달기
I had a similar issue with my computer showing the Stickies app being open, yet the Stickies were not visible.
  • Make sure Stickies is open
  • Menu Bar -> Window -> Expand
Hope this helps at least one person.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
guys real problem solver for disappeared stickies, check this link out , https://www.howtoisolve.com/sticky-notes...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sandy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 21
전체 시간: 14,304
