주요 콘텐츠로 건너뛰기
모델 A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 또는 3.4 GHz Core i7 프로세서, ID iMac13,2
330 질문 전체 보기
4sns 1 c0000008 tl0p 124
Hi I am getting 4sns 1 c0000008 tl0p 124 hard test error. The CPU usage over 400%
Update (08/24/2016)
I have changed the hard drive and bought owc cable + sensor as u adviced
Update (08/24/2016)
ok thanks a lot Mayer jan ( SSD upgrade and kernel_task )
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Did you change the hard drive?
I thought I recognized you. Let's delete this question and go back to the original. There was a months lapse between what I advised and your response and I missed it.
댓글 달기
답변 4개
선택된 답변
The problem was with the LCD sensor, no hdd sensor need for kernel_task problem. The HDD sensor is only for fans.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Is the fan running fast and making very loud. If so, you make to reorient a wire. It is either a heat senser or fan sensor wire.I don't remember the exact name. It has white dot on the conector. You need to turn it 180* from how it was before installed your new hard drive. Infix it has a very good guide that explains it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There is a sensor cable on some iMac models that must be attached to the replacement HDD for the fans to operate normally. I do not recall if the particular models include your mid-2010 iMac but the symptom you describe would be consistent with this requirement.
If you did not buy it from OWC / MacSales or other well-known Apple supporter, it is unlikely to have the required hardware.
Check with OWC to determine the correct replacement you require.
It's an issue in your lower slot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Has anybody solved this mysterie ??
I have the same behaviour:
And a kernel tast taking 300% CPU load
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You may find using this app will help in locating which sensor is failing: TG Pro See what it shows you.
댓글 달기
귀하의 답변을 추가하세요
Vardan Hovsepyan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,044
