주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iPhone screen flicker and touch is not working
hey, my phone suddenly start making white flickers on the top of the screen and the touch screen stop working. when i lock my iphone and reopen it, the flickering stops and the touch return to normal although sometimes even if i locked the phone and reopen it the problem remains the same. aside sometimes i feel that my phone turns too hot when flickering.
i took it to the technical support in my country, Lebanon, they told me that they changed the "AC " in the phone, after one week from the fixation date the same problem return to appear in addition to ghost touch and the silent/ringing mode change alone.
kindly i need advice what to do, if you can help me to know what is the thing that i have to replace in the phone to bring to its normal phase.
I love my iphone and I cant afford to buy a new one, I don't have an apple store here just some technician who fix all phone type. that why i need you help guys.
thank you in advance
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
The grey bar and non responsive touch issue is something that happens often with the iPhone 6 plus , i would normaly recommend you go to the apple store but as you mentioned there isn't one near by. Your best Option would be to atleast call Apple Support and see it they will be able to replace your device. If they are not able to replace it then you can always try paying for a Out-of-warranty replacement from apple (Cost is $329)
Heres a link to that support page.
https://support.apple.com/iphone/repair/...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi there,
I had an Iphone 6 plus (model LL/A) with the same problem as you are.
I don't know exactly the mistake was come from firmware or hardware. However, as my experience now, i think it is caused by firmware.
When this problem happen to me, the iphone was at IOS 9.3.3, i tried to shake, lock and open screen, restart, press on some edges of the iphone even bang it softly then the screen respond correctly some times but this problem happen more frequent and i could't used the screen although i tried all above actions.
Then, I called to the Customer care of Apple, they asked me to bring my iphone to the care center for checking and fix. Because my iphone was jailbroken, i had to restore its firmware. I restored to IOS 9.3.5 due to IOS 9.3.3 was signature closed.
After the restoration, my Iphone 6 Plus worked very well in 1 or 2 days before the problem came again. This time, I tried my luck with IOS 10 (14A5346a). And boom, my Iphone have been well since last Wednesday 7th Sept.
I would like to share this with you and all technicians of ifixit.com with the hope for a completely cure to our Iphone. Apple has been revoked us, we have to help ourselves.
Hope this can help many people in the world.
(Please don't charge for fixing this problem by my shares)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
malakrahal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 1,663
