Can I replace the Airport Board cable?
Hi,
I did a Headphone Jack replacement on my macbook pro 15' retina display mid 2012 laptop and on one of the last steps managed to break off one of the three gold circular heads of the antenna cables that attach to the Airport Board : S .
The middle cable no longer has a gold head but the other two are plugged back in properly. I believe it is the Bluetooth antenna because it is no longer working properly (i.e. only detects object that are very very near); Wifi instead is fine.
Could i please have confirmation that it is indeed the Bluetooth antenna cable?
I doubt I will be able to repair the cable as it looks like it has more than one signal in the wire. Would it be possible to buy a new/used antenna cable on its own?
좋은 질문 입니까?
댓글 1개
Did you end up doing the replacement? I broke the same cable and can't decide whether paying $200 for a new display assembly is worth it.
illya 의
