주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Why can't you buy a 6s digitizer without the LCD?
Hello. I'm new to repairing phones, so this may be a silly question, but why is it so difficult to buy the iPhone 6s digitizer without the LCD?
I've replaced a broken screen on an old iPhone 3GS, and the replacement digitizer I bought didn't have the LCD attached, I had to transfer it from the old display.
I would imagine that a digitizer without an LCD would be substantially cheaper than one with the LCD, so why can't I find any? Is it impossible to remove the LCD in the 6s? Is there a time period after a new iPhone is released in which you can't buy the digitizer separately? Or is there some other reason?
Thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
There is no digitizer, the touch function is built into the LCD panel.
The front glass is just glass, and it is directly bonded onto the LCD. It's not like iPhone 3GS that there are separate pieces. Unless you have the expensive equipment to peel the glass off and risk cracking the LCD every time, it is not possible to separate them.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
While Tom is basically right, he's not technically right.
There is a separate digitizer for the iPhone 6s. However, its bonded onto the LCD. You can peel it off if you try hard enough. However, the problem is getting a new digitizer on the LCD. The digi is bonded onto the LCD. It is possible that you could use some sort of heat stamping method to get the new digi on, but you have no way of getting it lined up. The process used to line up and bond the digi to the LCD involves a machine that uses x-rays and sometimes lasers to line everything up down to the fraction of a mm. It then bonds it in a special process.
So the quick answer is yes, you could save yourself the extra $30 that a screen with a digi attached would cost. But it would cost about $5,000 in machinery and I don't know how long in time to acquire the skill to get things right.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Well, iphone 4 and 4s has this kind of 3-layer design, LCD (display cable attached)+digitizer (touch cable attached)+front glass. Since iphone 5, the standalone digitizer is elimitated, the touch sensors are built right into the LCD, there is only LCD+glass.
take a look at an iPhone 5+ LCD. You'll see there is one cable for digi, one for LCD. Follow the digi cable back to the LCD and you can peel that connector off. Grab a razor and you can peel the digi off.
Like I said...you were right. But sometimes when troubleshooting a touch issue, its important to know that the LCD and digi are 2 different things and can malfunction independent of each other.
댓글 달기
Everyone's right except I have done this repair and replaced glass only...while it wasn't the easiest thing I heated it up and used a super thin metal wire and fishing line to separate the glass from the glue then I used one of theseHere= to line the new glass up the apply LOCA UV glue which has to be cured by uv light but once cured your ready to install So THERE IS NO NEED FOR $5000 IN EQUIPMENT
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm guessing its because of the 3D Touch layer on the iPhone 6s.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Michael Sligo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 262
