주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Both cameras not working
This iPhone has been dropped and has had a screen change. back camera was not touched, and was functional after drop and up to repair. front camera was functional after drop and up to repair. after repair both from and back cameras not displaying (black screen). i have checked both cables and have also changed front camera to test but no result. ideas ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Hi,
the problematic part is called U2301. U have to de solder chip and make a jumper between leg 1&2 (for fast repair -aprox 5 min)
Second method is change U2301 for brand new :
( http://www.ebay.com/itm/1PCS-U2301-Camer... ) -for example.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Yep. This is most likely the case. If the front panel connectors are unplugged with the battery plugged in or a metal prying tool used to unplug the front panel connectors there is a chance of accidentally shorting on or more components on the board. This U2301 ic component is located right near the front panel connector area on the logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Reboot Gozo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 8,424
