주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Phone heated up, smell burnt and wont turn on
Hi everyone,
I am repairing an iPhone 6 with cracked screen for my customer. Before doing anything, I unplugged the battery and put a new screen in to test it. I was testing the new screen fine then the phone suddenly heated up and I smell burnt; it then won't turn on. The battery is not original, I tried another battery and the phone still won't turn on.
Anyone knows what the cause of this problem? Is it because of the battery or sth else?
Thanks heaps.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You fried a power IC. The reason could have been a bad battery but more than likely it was damaged in the drop that broke the screen or had water damage.
Check the battery connector and all associated IC's under the scope and replace as necessary.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
thanhphu0410 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 8,923
