Machine will only agitate
Our washer will only agitate. It stop after the agitate cycle and won't rinse or spin. I've tried to just do spin alone but no luck.
좋은 질문입니까?
좋은 질문입니까?
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washer transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 1,106
