주요 콘텐츠로 건너뛰기
Why is the power button falling out of place?
I've faithfully and carefully taken my granddaughter's Nintendo 3 DS XL apart to replace the top LCD and am putting it back together. After I got the motherboard reattached with the ten screws and all the ribbons in place, I turned it over to check that all the buttons were functional and in the right place. When I touch the power switch, it falls out of place, like it doesn't have anything behind it to keep it in place. I've double checked twice and the power button is in correctly and the little gray rubber piece that covers it is seated firmly over it. What am I missing?
Thank you in advance for any advice.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Well, I feel really dumb. When I changed the shell and put everything back together, I didn't notice that the motherboard wasn't all the way seated, and it wasn't all the way seated because one corner of the lower LCD was popped out of place by 3 mm. It was enough space, of course, to allow the power button to fall out of place. Thank you for your answers. Even though they didn't answer what I eventually found to be the problem, I was so frustrated and it was nice to have the two of you make suggestions to me. I didn't feel so all alone. Thank you for your time and suggestions.
Ruth Crossett
댓글 달기
답변 2개
there was probaly somthing holding it in place that broke off, sadly, i think that i could fix the buttoun in place with a 3d printed part,also, if it isn't rubber, you also need sp®ings
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Check to see if there are any tabs missing from the power button. If there are, you'll need to order a new one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ruth Crossett 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 52
