주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
281 질문 전체 보기
Charger only working on one side
Hi,
Got a Macbook 12" where the charging lead is only working when plugged in one way, and not when reversed.
A bit of history on this, I replaced the LCD/polariser panel on this, and the customer mentioned the issue when they received it back. This issue was not picked up during testing on our side, so it is strange the customer has noticed this.
Tested on an original Apple charger, and using the customer's Apple charger. I have a lot of experience with this model and others, so I know the basic precautions (replaced around 15 LCD panels for this model with no issues). Tried SMC/PRAM reset.
Haven't tried a new charging port yet, since these are quite difficult to come by, and we have not got another of this model in at the moment to try the part from.
Has anyone else experienced this issue? Could only find one other person online with this problem, and it was on an Apple forum, so there was no real information. Did not notice anything unusual when doing this repair either.
Thanks for the help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Issue was related to the board side charger cable connection, which was partially plugged in. I unplug from the charger port itself, not the logic board, so this may have happened when loosening the logic board screws to disconnect the battery.
Just a heads up for anyone with this issue in future :)
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
You mean it was from the charging port flex cable plug on the motherboard
@hamoudihaidoura 5 years late but for the sake of clarity: The 2015 MacBook is socketed on the USB C plug board AND the motherboard with a cable between the two. So I suspect they did mean the cable was disconnected at the port itself, not the logic board/motherboard. The 2016/2017 MacBook changed this and had the cable soldered to the port board.
댓글 달기
귀하의 답변을 추가하세요
Reece 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 2,538
