주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
I replaced my iPhone screen and it is now not turning on
I just replaced my iphone 6 screen for the second time and this time it won't turn on at all. When i've tried to charge it there has been no vibrate and itunes doesn't recognise it. I'm at a loss to as what went wrong as last time it went perfectly and i followed the exact same steps... Also, i know it's not dead as it had battery life before turning off.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Try disconnecting the battery, holding down the home button for a few seconds to drain any residual power, reconnecting the battery and then hard reseting the phone (Power + Home until apple logo appears). I have found that this little trick works quite frequently.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
This. It seems to happen if you accidentally power on the iphone while the screen is unplugged and then fit the new screen. Just a hard reset is in most cases enough. Sometimes reconnecting the battery aswell.
Just an FYI: Battery should be unplugged at all times when doing repairs, only have it plugged in when you need to during testing. Never during replugs of other connectors.
댓글 달기
귀하의 답변을 추가하세요
Megan Birks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 73
