주요 콘텐츠로 건너뛰기
The HP LaserJet 1200 is a monochrome laser printer produced by Hewlett-Packard.
10 질문 전체 보기
USB Printer Port to connect to computer is not working
The printer works but the power between the printer and the computer is dead. I am certain it is the USB Port Prongs that are the problem. I have tried several other cords and still get the same outcome: nothing. Can I simply change out this port? Where can I buy this port replacement? Many thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Can you tried an USB-HUB? If not, try to use a USB-HUB to try at first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Since your USB port appears to be non-functional, I suggest switching over to printing via the network, print server, or WiFi using the HP JetDirect port. You may need to purchase something extra to get this to work, but is easier than resoldering a USB port.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Katharine Atchley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 507
