주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 9일에 발표된 이 기기는 Apple의 첫 번째 스마트 웨어러블 출시제품입니다. iFixit의 수리 설명서는 Apple 워치 (스틸) 및 Apple 워치 Sport (알루미늄)에 적용됩니다.
bottom charge / pulse sensor
My aplle watch bottom cover came off with the charger and the ribbon cable is broken. The two small cables for charging are still intact and I can still charge the watch but the pulse sensor is not working. where I can buy replacement sensor?
Thank you in advance
Update (09/10/2016)
Yes I saw that section but there is no sensor there. I know it is a common issue that the back of the watch is falling while detaching the charger and I was curious why there are no replacement parts for this issue. And the replacemet is prety simple. there is only one ribbon cable with connector and two tiny wires that have to be soldered for the charging and that is it. This is the needed part.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 7개
가장 유용한 답변
Depending on which Apple Watch model you have you can find all our replacement parts here:
https://www.ifixit.com/Store/Parts/Apple...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
when you remove the bottom cover you will see this
. Just unplug the connector, and remove the black tape from the two tiny charging cables. one of them is marked with red or white and it must be soldered to the upper point
. and that's it. only the part is hard to find. I used broken watch to take the sensor but it is good to have a new/replacement one too
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Is this the part that is needed to be replaced for fixing this issue?
Apple Watch (38 mm, Original & Series 1) Rear Cover
This plastic rear cover includes 4 sensor lenses. 이미지
제품
$9.99
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi, this is just the cover and it does not include the coil for charging and and the sensor.
댓글 달기
Hi so the watch charges with the two antennas attached and not the ribbon
이 답변이 도움이 되었나요?
점수 0
댓글 달기
So when I solder the two wires back do they need to go in the old solder or can I just put the wires on top then solder over them? The charging wires came off
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Do the wires have to go directly into the previous soldered pads that they were once connected? By directly I mean like the hole they once where connected or can I just peel the wires a little and then place them on top onto of the old soldering pads And just solder them? I guess my question is do they need to make contact with anything specific or not really? Just place solder and that’s it?
댓글 달기
the Wires go on separate pads the one with the white marking goes to the right if I can remember research to be accurate but I put the wire on the pad and took my solder iron and press down delicately until the solder became liquid tweezer would help also a magnifying but I used neither and actually I didn’t have a solder tip at the time just used the hot coil from the iron and the solder pad that was already there didn’t bother with the hr didn’t have the tools definitely recommend microscope for that
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's available from repair universe. It believe it was a apple series 1
it's only 10 dollars and I also found the cover and all of the other cables and repair parts if you would like that information.
Update (05/10/2020)
I haven't worked on an apple watch but there are probably videos on YouTube. I would watch all of them. I hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have that I just want to know how to solder the battery wires back like do they have to go inside a specific way or just place the wire on top of the previous solder and just place new one and that’s it it’ll work
댓글 달기
답변을 추가하세요
Nikolay Kolev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 1,202
