주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
iPod Touch 5th Generation Logic Board Assembly Replacement
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
iPod Touch 5th Generation Rear Case Replacement
Good luck!
iPod Touch 5th Generation Logic Board Assembly 이미지
안내서
난이도:
어려움
1 - 3 hours
iPod Touch 5th Generation Rear Case 이미지
안내서
난이도:
어려움
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
Great answer! You need some more rep!
댓글 달기
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
This has already been resolved and accepted.
댓글 달기
답변을 추가하세요
Zubair 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 187
