주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
9741 질문 전체 보기
won't start - wet keyboard may be the issue
my son was wiping the keyboard with a 'damp' cloth,
now it won't start... at all
the battery shows a charge
no action when attempting to start
could it be just the keyboard?
I could replace that.
Could it be something else?
What are the options?
TIA
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Mayer: Thanks so much for addressing my issue.
Still no action.
The charger lights up when attached but the battery does not appear to be charging.
There are no sounds of any kind when I attempt to start the computer.
I'm thinking it's not the power supply as the charger lights up (and I think that makes for completing a circuit) but again, no battery charge and the machine won't start.
He was using rubbing alcohol to clean the keys, I don't think he turned the machine off first as he said it worked fine until he shut down,,, then he could not restart,
Is there a way to test components without having to purchase replacements?
댓글 달기
답변 1개
가장 유용한 답변
Shut it down and let it sit for a couple of days. Try to find out why he was wiping down the keyboard.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I would remove the battery while its sitting. The question about why is a good one--if he spilled something on it you should disassemble it and clean it out and then dry it. Good luck. +
댓글 달기
귀하의 답변을 추가하세요
Doug Brooks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,002
