주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Home button cable broken
I have an iphone 5s that was "repaired" by a shop. The power button cable was broken and resoldered with gold wire. The home button cable was broken. The shop told my daughter that the logic board was going bad. I replaced the logic board and upper component cable in the phone, however I still get a blank screen when trying to turn it on. Will the home button cable being broken stop the phone from starting? I have tested the battery pack and get voltage. Is there a way to see if the display is bad with an oscilliscope or voltmeter?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I'm wondering why on earth did they use a gold wire to resolder the power button cable. Replacing the part is the proper fix for that.
For the home button cable broken, the solution to get the home button working again is to either get the home button (comes with cable) replaced or the wire resoldered which is literally near impossible to do if you want to keep the touchID functionality.
Because the fingerprint scanner on the original home button is linked to the logic board, a replacement home button will not have the finger print scanner working.
The repair shop should fix the phone at least as to the condition the phone was in when you bring it in. Sounds like the repair shop broke a few cables which shows they may not have adequate experience in doing iPhone repairs.
A teared / broken home button cable will not stop the iPhone from turning on if you keep it unplugged.
I don't think you can check if the display works with a oscilloscope / voltmeter. The only way I'm pretty sure is to try another screen.
Can you shine a flashlight very close to the screen to see if it is displaying anything (if you just tried to turn the phone on you may need to wait a bit for it to boot up as it will show apple logo first usually).
Have you tried connecting it up to the computer and see if the application iTunes detects the device?
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I don't see anything with a light next to the screen, nor does iTunes detect anything so it isn't booting. I appreciate the help.
댓글 달기
귀하의 답변을 추가하세요
gpgreen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 482
