주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lytro의 첫 번째 라이트 필드 카메라는 2012년 3월에 출시되었습니다.
How to disassmeble Lytro first generation camera
How can you take the Lytro First generation camera apart?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
I know this is an ancient question, but I just came across a small cache of broken Lytro first gen cameras and decided to write a teardown guide:
Full Lytro First Generation Teardown (The Easy Way)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yo! I was the designer and mechanical engineering lead on the Lytro cameras (heavily supported by a crack team at a major Taiwanese JDM). This write up is pretty solid, nice work Mr. Calvin. I'll just add a super inside baseball note that many times issues would arise where going the official route was a pain outside of the factory, so if your issue just requires reseating the camera cables or swapping around front / rear assemblies you can do that without disassembling the display / battery / board stack and all of its many hard to replace tapes.
If you just want to mess with the front end... 1. use a spudger or guitar pick to pry off the front plastic cap starting along the top edge where the tape is thinnest. 2. Remove the very custom fabbed long screws. 3. Gently pull apart the front and rear halves, hinging at the top edge where the ribbon cables hang out. 4. Use the phillips head of the long screw to reach in and open the ZIF ribbon connectors for the lens:board interface. (5-n. do whatever you gotta) 6. reverse steps, which is super dextrous work on those cables but very achievable with patience.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
raymondrhooper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 43
전체 시간: 802
