주요 콘텐츠로 건너뛰기
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 질문 전체 보기
My moped dies when I am not constantly turning the throttle.
I am new to working on my moped so any help would be appreciated, i also have more questions but this one is my main concern.
So i can start the moped no problem its a little rusty but in order to keep it running i have to have the throttle turned a bit, is that normal?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sounds like you might need to adjust the idle.
Try adjusting these two screws and see if you can get it to idle without hitting the throttle.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
Chase as Randy C. suggested try the idle mixture screws first, if that does not do the trick, the carburetor will probably have to come apart and be clean/rebuild.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Also check that the gasket is sealing(no vacuum leak)base of carb. to intake on cylinder,
댓글 달기
귀하의 답변을 추가하세요
chase 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 44
전체 시간: 6,864
