How to factory reset this tablet
how do i factory reset this pc tablet Envizen digital emdoor digital
์ข์ ์ง๋ฌธ ์ ๋๊น?
์ข์ ์ง๋ฌธ ์ ๋๊น?
I would try holding power + volume down, if it doesn't work try holding power + volume up, if it doesn't work try power + volume down + volume up
ํด๋น ๋ต๋ณ์ ๋์์ด ๋์์ต๋๊น?
The power and volumen up worked but when it gets to the pi, ture of the Android iy Just stops
I also had the same issue, purple tablet with dvd player, +and power up gives the option to do factory reset, it goes to a logo and sits there for a long time, and boots back up after several minutes with no change. still requests pin code and doesn't appear to have reset, tried twice, can not find any info on this company or any other solutions anywhere.. so much for customer support.
Can not swipe the screen. it is frozen
try factory reseting it or maybe take out the battery. If that dose not work take it to the place you bought it and ether ask for a refund or replacement
24 ์๊ฐ ์ : 3
7์ผ ์ : 13
30์ผ ์ : 18
์ ์ฒด ์๊ฐ: 2,480
i tried all those short cuts to factory reset it but none wont work
kareemspooner637 ์
@kalan what is going on with your tablet? what does it do? Do you get to any menu? Stuck at the Android logo? Give us a bit more information.
oldturkey03 ์
Mine is stuck won't reset I forgot pattern unlock code can't reset to factory any help appreciate it
Blake Anderson ์
mine was given to me as a gift and the person forgot the password they set
destinybryson ์
