주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Remove streaks from LCD after cleaning glue residue
Hello,
I would like to know if before applying LOCA/OCA I must remove the streaks left from the product I use to remove glue residue on the LCD screen after having removed the broken glass.
I'm asking this because I've no problems removing the glue but I would like to know if leaving on the screens some streaks caused by the cleaner I use can cause an imperfect glass repair only (polarizer with spots, bubbles or something else).
Thanks in advance everyone :)!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hey, thanks for your answer.
No, it's not the glue leaving the streaks but the cleaner I use.
One last question: even when I have to put the polarizer film on the iPhones' LCDs can I leave the streaks? Or I'll see marks underneath?
Thanks again!
댓글 달기
답변 1개
선택된 답변
At my shop, I refurbish screens everyday. You do not need to remove the streaks. The glue will cover that up!(as long as it's not glue that's leaving the streaks)
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Thanks again!
You can leave the streaks on bare LCD's as well, but I personally try to clean it 100%.(I'm such a perfectionist....haha)
Ahaha I see, so what do you use to get a perfect shiny streakfree LCD?
Sorry for the late response!! I use only a small dab of 91% rubbing alcohol on a clean microfiber clothe and it takes all streaks away!
댓글 달기
귀하의 답변을 추가하세요
Roberto Silvestri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,176
