주요 콘텐츠로 건너뛰기
곡선의 슈퍼 AMOLED 터치 스크린 디스플레이를 장착한 Samsung의 피트니스-중심 스마트워치. 2014년 4월에 처음 출시되었습니다.
35 질문 전체 보기
Why will my Samsung Gear Fit no longer charge?
I've had this for about 9 months now (had another, but lost it on a mountain), and it just stopped being able to charge. Tried switching cables, but that didn't help. Watch is now dead and still not charging
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Usually it’s corroded or dirty contacts. If they are only dirty, You can clean them with a small screwdriver or Q-Tip and some cleaning alcohol (Don’t drink! Just apply to contacts!)
Or you can change the contact-plates yourself. There is even a very good video on this on YT (https://youtu.be/vxvehGQG2YQ).
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Replace the battery..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Check the backside of the watch. I have a similar problem except my issue involves the 2 visible copper charging contacts being corroded and rusting off from perspiration, and also showering with the watch on. My contacts will need to be replaced very soon in order for my watch to continue to charge. In your case...I would check to see if those contacts are damaged. If not, I think the earlier comment to change the battery would be a wise second step. Hope this helps. I'm just browsing right now to find a way to order those copper contacts. Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Trevor, I also have the same problem with my copper contacts. Have you found a solution? I dont find help on this issue. TiA. Good luck.
댓글 달기
귀하의 답변을 추가하세요
thechessmeister 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 35
전체 시간: 2,149
