주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
White screen with lines
Replaced the 3.5 jack and harness, as I've done 2 other times. This time though, when i powered back up, the screen was white with a few dark blueish verticle lines on left side of screen and small horizontal lines on entire screen. What could have happened??
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Probably the lcd ribbon / flex cable damaged which in results in needing a new screen.
댓글 달기
답변 2개
try this
Press and hold the home button, then the up-volume button, then the sleep/power button (so all three buttons are now pressed and held) --- it takes a while, but the white screen will go away and then after another 10 seconds or so (still holding btw!) the apple logo will come up, release the buttons and then wait, it'll boot normally again in a minute or two.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try disconnecting the LCD connector and reconnecting it (make sure the battery is disconnected while you do this) just in case it came loose. If that doesn't work, then you will need to replace the screen.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mandalorian75 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 554
