주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
I want to upgrade my wi-fi card to get faster transfer speeds
I have a Apple Airport Extreme 802.11 ac Wireless Router but own a 27" iMac Mid 2011 EMC# 2429 computer with a 802.11 N wi-fi blue tooth card. I want to upgrade it to get the 5GB wireless speeds not the 480MB I get just using the factory installed wi-fi card. Is that possible since it still has the factory installed 2.0 usb ports with a 480mb max data transfer rate? Can the USB ports be changed also?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
There are a few ways you can get faster WiFi connections. The easiest way is to just get an Airport Extreme router which you connect via Ethernet to your iMac, then let it make the WiFi connection to your AP in the other room. This is what I would do.
The next option is to upgrade the WiFi board in your system, but it's not easy and you won't get MIMO so it won't be the max of Phase1 or even Phase2 802.11ac which many routers now offer. Here is one source for the needed kit to replace both the WiFi & Bluetooth boards you currently have in your system to a combo card: Apple WiFi + Bluetooth 4.0 card to MiniPCIe Adapter for 2009, 2010 & 2011 iMac's.
Both of these solutions don't address the USB port part of your question.
To improve this you'll need to use a Thunderbolt dock which then offers USB 3.0 services. There is no means to alter the internal systems USB ports.
If you decide to do go with a TB dock then you could connect via the faster USB connection a USB WiFi unit which could get you an 802.11ac connection.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
workmanterry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 760
