주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
About Memory slots on Mac mini
What happen if the memory removed many time from memory slots many times may happen erosion in the lips that found in the middle of slot "and i mean erosion , the picture clear my mean" and the first remove to the memory i found a simple erosion as the picture clear and i remove the memory in the correct way so it an normal or not
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Most of your internal connectors are not designed to withstand constant disconnect/reconnections, that includes the RAM slots.
I would say more than 8 times is about the breakpoint. Why are you swapping in and out the RAM so many times?
Update (09/22/2016)
The image looks just fine! The slot pin is not designed to be bottomed out with the module if that was your concern. Here's an image from the IFIXIT teardown: Memory modules seated correctly in the slot so you can see its the same.
Lets backup here ...
Forget about the RAM for now. What is happening with your system is it working or not? If not explain what you are seeing as best as you can. Did you replace something? Did you smell, hear or see something?
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Everything is good i just asking about this point and i didn't smell anything and i didn't hearing anything and i had made Apple Hardware test and the result was " no trouble found "
Thats great! You had me worried ;-}
댓글 달기
답변을 추가하세요
mohamedhaitham36 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 494
