주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 질문 전체 보기
What is this bright white discoloration on the edge of the screen?
Here's the image of what it looks like.
That image (found in google) is exactly what is happening to my screen, though on a less severe degree. Not very noticeable when the screen has color on it, but in games like Pokemon, where you encounter a black backdrop within buildings often, it gets annoying.
Does anyone know what it is or how to fix it? Thank you~
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
This can't be fixed. This is what's called "backlight bleed". I have a Game Boy Advance SP and mine does the same thing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
What model of the GBA SP do you have ags-001 or ags-101? If you are not sure, check the label on the back of the GBA SP and it will be listed in the top left corner. If you have an ags-001, which is the launch model, it is frontlit as opposed to the ags-101 model which is backlit. I have a GBA SP Special Pikachu Edition that I got for my birthday in 2005 and I have never had this problem. I also have an original Gameboy Advance that I modded to have an ags-101 screen and I have never had a problem like that with that system either. The only time I've seen something like that with a GBA SP is with the ags-001 model and that's always going to happen because of the way it is frontlit.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes you can fix this. This is the backlight is broken or it is bleeding. You need to replace it in order to fix it. You can find this replacement on this website. So it is possible. You just need the new backlight screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tobi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 44
전체 시간: 3,855
