주요 콘텐츠로 건너뛰기
The BLU Vivo 5 is an Android smartphone produced by BLU, an American consumer electronics company. The 5 was produced through a partnership between BLU and Vivo Communication Technology Co. Ltd., a Chinese technology company. The BLU Vivo 5 was released in February 2016.
Where did my call log and messages go?
So I have all of my contacts but all of my messages and call logs disappeared. When I go to my settings it says I have all of my messages but when I open the app or hangouts I have zero threads. It will also notify me when I have a new text message but I cannot see said text anywhere. I tried resetting my messaging settings and it didn't work. I'm incredibly confused. Help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 3개
I have a vivo y21l phone but after 4 months of buying it does not show any recent calls and missed calls rather it shows old calls what to do next..
Have you solved this problem? It happened to me. But i still cant fix it
Hello
I have vivo v5 and i was block a number and the block number and messages remove from my message inbox.
My all messages go in to i manager block messages.
I want to move that all messages from i manager block message inbox to my vivo v5 default message inbox after unblock that number.
How to fix this issue please help me to fix this issue.
Thanks
댓글 달기
답변 11개
가장 유용한 답변
It may be because you accidentally turn on the "guest mode".
My sister also has a vivo 5 and experience pretty much the same problem. She can't see any call log, and all the picture in the album are gone.
In the file explorer I was able to find the pic under DCIM folder, but don't have the access to view it. The phone pop me a message saying I was not allow to see them because I was in the guest mode.
So I go to setting->security-> and turn off "guest mode". Everything come back, hope it also work for you.
이 답변이 도움이 되었나요?
점수 25
댓글 22개:
Oh. Fantastic. Thank you very much for your suggestion. I had the same problem and I very much worried. After seeing your suggestion and tried off from guest mode. I the problem solved. Thank you very much.
Thanks you I turned off my guest mode like you suggested and my call and messages are back,, thank you sooooo much
I can't find the guest mode on my Vivo 5R.
Can someone help me ASAP. Justice
I can't find guest mode either, any help?
Thanks.... It works
댓글 17개 더보기
댓글 달기
Justice Sackey I emailed Blu support and they told me to go to settings, security, unknown apps installed, open it download guest mode doc, then you can close that setting back to unopen. It worked I got everything back.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
What is the process of delete call log in vivo v5 phone
@aliceca , I have same problem with 5R, I cannot find "unknown apps installed". Is it hidden under other section? Thanks.
After the phone being updated to the latest version *v24_generic_6.0_07-6-2017, the "Guest-Mode" check box showed up on "Settings" - "Security". Finally, I got the call logs back.
I'm experiencing the same problem. I am unable to find any of the options in security, and not sure how to get the phone to update as mentioned above. Would be grateful for any suggestions... cheers
I have an XL2 with the same problem, I followed the instructions and got everthing back. Thanks @dzpcool!
댓글 달기
Thanks for this info...I now have my messages, pictures and call log back.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It worked for me .Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
hey everyone, I have vivo xl and after a certain date I have lost some messages. I never lost my call log or contacts... HELP!
댓글 달기
This is probably because your guest mode is turned on. Go to settings>security>guest mode and turn it off. Hope it works for you.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It doesn't have that option when I click security
댓글 달기
Hello
Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have Lenovo k6 note with venom os
I can't see my recent calls and messages..
What to do ??
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same here. I can't see my call log or pictures.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Your a deleted it or your phone glitches out. Don’t be too hard on your self, computers are complicated.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I can not see the Miss calls numbers on my
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Thank you,
Your answer to the problem worked like a charm. Resolved within 30 seconds vs. my having spent a lot of useless time before reading your answer. Thanks again. Mike M 3/25/2020
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Angie kriess 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 71
전체 시간: 35,249
