My screen is dark can it be replaced
the screen on my Macbook is dark , the book works but I can't see anything on the screen, is it repairable?
좋은 질문 입니까?
좋은 질문 입니까?
At this point your system should be under warranty. I would visit an Apple Store or authorized service center to have it fixed.
If you have any damage dropped or liquid then all bets are off for a free repair. Please explain what happened we still might be able to help you.
해당 답변은 도움이 되었습니까?
I already took it to an Apple store, it's under warranty but they say it was damaged by someone or something that they do not cover
@brookievangogh - Rosie did they say what was damaged here?
Any local PC store must be able to replace the back light. Even you if having enough technical skills could do it (check iFixit manuals).
If doing by yourself, disassemble your lcd and look for the part number. You cant then order through ebay.
Compare with Apple store services, you could save + $150.
Good luck and good repair.
JM
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 92
댓글 2개
Are you able to connect your system to an external monitor and see an image on it? You'll need a USB-C adapter cable.
Dan 의
I can see some light, but just like lines or something, it turns on, Apple Care told me the software is fine the inside hardware is fine is just a damaged screen and the warranty doesn't cover damage to the screen
Rosie 의
