주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Why can I not click by pressing down on my trackpad
I have a 13" macbook pro, first unibody model from 2008 (2 gb ram, 2.26 ghz, 160 gb).
I used to run it on snowleopard untill recently. i could not press down on the trackpad to click. after clicking about 10 times, the laptop registered only 1 click.
But the trackpad was fine otherwise, it could sense my gestures and taps just fine.
i had the touch-to-tap option turned off, but i had to turn it on to use the laptop.
As my laptop was under warranty, i took it to the service centre. the guy opened up the laptop and said the trackpad was fine, he asked me to erase the hdd and re install the OS.
I did and my laptop was fine again
That was 3 weeks ago. now my laptop cannot click when i press down on the trackpad again. i run leopard 10.5.8 now. please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
The 2.26 was 2009:
Apple MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) Specs
Identifiers: Mid-2009 13" - MB990LL/A - MacBookPro5,5 - A1278 - 2326*
댓글 달기
답변 2개
가장 유용한 답변
Introduction Date: June 8, 2009 Discontinued Date: April 13, 2010
Please give us the last three letters of your serial number. This machine may still be covered under warranty. Take it back and make sure there is a record of your returning it. I would take out AppleCare to extend my warranty. If it's doing the same thing with 10.5.8 as 10.6, try upgrading to 10.6 again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Good answer +
댓글 달기
I had the same problem with my trackpad. When I got it the physical click was a bit difficult to register (I had to click hard to have it register). Now a year and a half later it's just worse. I practically have to mash it down with an uncomfortable amount of force to make it register.
I would think if it makes the "click" sound it should be registering but this is not the case.
I read somewhere that you can adjust the sensitivity by a torx screw on the bottom of the trackpad. By opening the MBP and removing the battery I see a torx screw but I don't have a bit to fit it.
I do not believe this issue is a software issue. It happens in Leopard, Snow Leopard, Windows 7, and Ubuntu.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tapas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,148
