주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iPhone dead and will not charge
So I dropped my iPhone 6 Plus and the screen smashed but still worked for a couple of seconds, but I replaced the screen and now the phone won't even turn on or even go into recovery. I got iTunes error 4005 when I put a new battery inside it but all it did was heat up the area where the A8 chip was . Help many thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
Heating is not a symptom of a charge port.
Its almost always a fuse/filter that got knocked off. Part of what the charging system of the phone does is tell the phone when the battery is dead and in return, the phone kicks more juice to the battery. When part of that system is broken, the phone will throw full current to the battery. This makes the battery get very hot and it can even explode.
Its a relatively cheap fix, however it does require micro soldering skills and equipment.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Battery doesn't heat up, the area where the A8 chip gets hot
댓글 달기
try to change the charging port
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
I've already changed the charging port, it's got a new battery
댓글 달기
귀하의 답변을 추가하세요
Chris Hollands 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 206
