주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 non responsive
I went to bed and plugged in my iphone 6 (had 15% power) to a non apple power block plugged directly into the wall (no surge protector)....it was powering up when I fell asleep. I woke up to the phone not responsive at all.....won't turn on or show anything on the screen. I am familiar with how to work on these phone somewhat so I opened it up, checked all the connections, check the battery connection, etc......and still nothing.
I ordered a new battery (just in case) and replaced that as well, still nothing. Went to the apple store/genius bar and the guy said the charge port is working but he couldn't get anything from the phone either. He mentioned maybe a power surge or something.....it had rained the night it happened.
My question is does anyone have a best guess on if or how I can fix this myself? He said it might be a "fried logicboard".........so if that is the case, can I do this repair? If yes, whats the deal with the "cloud locked" etc stuff? I am very budgeted so I am looking to do this repair as inexpensively as possible. Thanks for any help/advice, much appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
This question was migrated from http://meta.ifixit.com/Answers.
Do you know if the new battery came with enough charge for it to turn on?
iCloud locked logic boards are basically stolen / lost iPhone boards that are locked to an appleID where you can't activate the phone when setting it up (after restore or on setup screen) which makes the phone unusable.
I would try another charging dock just to be sure then if not I would say most likely a main board issue, not sure if it's fixable.
댓글 달기
답변 1개
Did you try a hard reset? Can you get into recovery or restore mode?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Derek Dean 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 132
