주요 콘텐츠로 건너뛰기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
294 질문 전체 보기
Can't get top right corner screw back in.
I took apart my iphone 4 and, as expected, had trouble removing the top right screw (near the audio jack). Now that I am trying to reassemble, I CAN NOT get the screw back in. I have been working on it for an hour.
I am using the tool kit from ifixit and the screw driver hand is too thick to be able to get a direct line on the screw. I need some advice on how to proceed.
1. Is their a screw driver with a longer thinner shaft that might work?
2. What happens if I leave the screw out altogether? (I did try that but the reassembled phone is unresponsive.
Any other ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi !
As long as this screw is a contact screw, there's no surprise about your phone not responding once reassembled.
I suggest that you use different screwdrivers, not being able to give you an accurate reference as long as I no longer own an iPhone 4. If you still can't manage to screw it or that the head is a bit damaged, some tools sold f.e. at iFixit may help you. I personally use this one for damaged screws.
Screw Extracting Pliers 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
The screw head is still undamaged. I just can't get the screw driver and driver head alligned.
Have you tried with a flat one ?
댓글 달기
귀하의 답변을 추가하세요
A S Koski 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 41
