주요 콘텐츠로 건너뛰기
5W Mighty Dwarf Omnidirectional resonance speaker.
7 질문 전체 보기
The red and black wire came out
Hello my name is nokia Thompson, I acidentally knock it over when I was putting something up and it didn't shatter but the bottom peice shows the blue battery pack I think? It has a red and a black wire but on the inside bottom of the speaker it's wires are still connected. Is there a way to connect the other red and black wires?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
nokia, both wires will have to be rejoined to corresponding wire, normally wires would be stripped of a little insulation, shrink tubing put on/slid over wire out of way, stripped copper wire meshed or twisted together and soldered to secure connection. After solder cools feed the shrink tubing over the soldered joint and heat it with heat gun or carefully with small flame till it shrinks, rapping tightly around the joint. Electrical tape can be used in place of shrink wrap (just not as reliable I feel).
Check the attached Video link, instruction and guide on how to solder wires, Good luck
I hope this helped you out, if so let me know by pressing the helpful button
https://www.youtube.com/watch?v=Q9G9gaok...
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You'll be looking for a local electrocution or wiring company for this if you don't feel like going out a buying speaker cable and a soldering iron. Wouldn't cost you much either way.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nokia Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 12
전체 시간: 506
