Voltage of "backlight sensor"?
I had a small coffee spill a few days ago (see pic for spill area) and I shut it down immediately. After a thorough cleaning & 3-days of letting it dry out, I put it all back together.
Only noticeable issues:
• The keyboard backlight doesn't work at all
• There were a few moments of “brightness flickering” when I had my iPhone charging/syncing via USB & my display brightness was set to "automatically adjust". Keeping my mouse USB plugged in has no effect.
• There are "cones" of lower brightness on the lower section of my screen (see pic). However, I'm 75% sure this was an existing issue which I never remembered to fix (because I keep my dock dark).
Anyways, while I wait for my Genius Bar appointment in a few days, I'm keeping an eye on my sensors with the iStat Menus app. But I couldn't find any definitions or explanations of what normal sensor ranges should be.
What doesn't make sense to me: the "backlight" sensor voltage is at ~40V (at any brightness, regardless if it's running on battery or charger) while my "DC-in" sensor is ~20V.
Is this normal for the backlight sensor to be at ~40V? Also, where does the keyboard backlight originate from? Does the keyboard cable have anything to do with it? Because it's slightly damaged on the edges (see pic).
TL;DR Minor coffee spill. After cleaning/drying, only issue is keyboard backlight not working. iStat Menu reports a “backlight" sensor voltage at ~40V while the "DC-in" sensor is ~20V. Is this normal?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
