주요 콘텐츠로 건너뛰기
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
171 질문 전체 보기
Red Light issue .
Dear
The basic problem I am facing is that when I turns on my Xbox 360 ( yr 2011) It shows a red light on power button just like the green light at all corners and just after it switches off
Red Flashing type
Please help me out
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개:
is it red and green? or just red?
When it open its green and then it goes to red and then off
My Original Xbox is Flashing red-green..
The problems started a few months ago, when changing region to play 720p and 1080p games, everytime i starting the console it reboot endless times and not enter unleashx, i've to press a special sequence to enter unleashX safe mode, and load games etc..
last week i'm in good mod to understand the issues and resolve the problems, and have reseted the configs in unleashx and i see that some settings dont save after a complete power cycle, like default resolution, image soften filters, etc.
I've inspected the board and cables and everythings looks ok, without any capacitors leaking or white marks of older leaking componentes, and that said i've put back all toghether and leavit for another day.
yesterday, just simply power on and it's shows Error 12, and flashing red-green. I've tried another IDE cable same issue, the DVD drive dont read any disc right now(and is working a few months ago)..
Any help?
댓글 달기
답변 1개
Solid red, overheated.
Flashing green, bad bios load.
Flashing red-orange, bad video output.
Flashing orange-green, AV cable not plugged in properly.
Flashing red-green, system faliure (can be alot of things).
well Heres A basic Breakdown on the indicator lights hope it helps..
a lot of times i have seen this issue and been able to fix by disassembling
cleaning and reassembling so I would try that first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Abdullah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 11
전체 시간: 2,824
