주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
비디오 게임 콘솔 개발 회사로 시작된 Sega/세가에서 개발한 비디오 게임 콘솔의 포괄적인 수리 정보 세트입니다. 2001년 1월 소프트웨어 개발에 집중하기 시작하였습니다.
Graphic and Sound problems!
HeyHo,
I bought a used Sega Master system 1 Power Base, PAL with antenna cable and the game "Alex Kidd in Shinobi World".
Well, the system works fine but there is a deep buzzing noise at the background. The noise does also change pitch from normal to low, to high....
And the graphics are really messed up. There are huge black transparent scanlines from the bottom to the top of the screen. And at the point where the scanline is, the game changes to black and White... oÔ
I Tried:
  • Another Antenna cable (From NES/Famicom)
    • Nothing Happened. Same Errors.
  • I soldered in a A/V Connector.
    • Same Problems with graphics, but no sound (Allthough I did solder correctly.)
  • I Tried to hook the Game system on a CRT TV (Mine is Flat)
    • Still the same problem...
  • I cleaned up the whole System. Every contact of every connector was cleaned.
    • Of course the error still appears.
  • I Cleaned the Game Module.
    • Same Problem -.-
  • I Opened the system, but every cap, every contact and so on was fine.
I hope you can help me or make a suggestion.
Thanks folks,
Kentsfield
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Wow. That's a little out of my league. Try these places for some extra help. I'm sorry, wish I could help you further.
Genesis A/V Pinout
Genesis Mod Forums
Master System Scart pinout
Good luck!
==Update==
Maybe these will help too.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks, man!
You're Awesome!
With this schematic I can try to fix this problem.
Anybody else got suggestions?
댓글 달기
It is the capacitors. Common issue. I sell them on ebay. Look up sega master system capacitors
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kentsfield 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 5,658
