주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
402 질문 전체 보기
MacBook Pro slow battery charging
Hi
my macbook pro is very slow charging (about 10 hourse!)
there is (sometimes) horizontal line at start up (I repeat only sometimes)
I changed charger and battery but it doesn't solved
is this from logic board?
please help
Best Regards!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
The next step in the troubleshooting process would be to try and replace the magsafe port, if you indeed know its not the physical charger itself. This sits between your logic board and charger. If you are noticing slow charges and have eliminated the possibility of having a bad charger, it's possible your magsafe port is showing signs of its age. If I am not mistaken this is the part you should be looking for.
iFixit Guide
Edit = Repair Guide Link
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
thanks again for your reply
is this possible to test it with multimeter to understand dc in board is faulty?
best regards
Hi
I changed " magesafe DC in power board" but no luck!
please help!
what can I do?
Best Regards
I also have had this problem for quite a while. it isn't the magsafe DC-board so I suppose it's a chip that got short-circuit. But I have no clue where or what needs to be replaced..
댓글 달기
Take it in to an ASP and have it tested for this issue:
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi
thanks for your reply baaut in my country there is no apple service
pelase help
best regards
What country is that? We may know sources that you are not aware of.
댓글 달기
Ordered one and will have at it this weekend. Hopefully this is the fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nicolas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,836
