주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
DDR3L or normal DDR3?
Hi! Do I need normal DDR3 or the lower voltage DDR3L RAM for my mid-2012 Macbook Pro? Everyone says something different. Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
Best answer here is to use what Apple documents: MacBook Pro: How to remove or install memory. Here's what Apple states:
MacBook Pro (13-inch, mid 2012)
  • Number of memory slots 2
  • Base memory 4 GB
  • Maximum memory 8 GB
Memory card specifications:
  • Double Data Rate Small Outline Dual Inline Memory Module (DDR3) format
    • 67.6mm x 30mm (1.18 inch)
    • 2 GB or 4 GB
    • 204-pin
    • PC3-12800 DDR3 1600 MHz type RAM
Additional notes: For best performance, fill both memory slots, installing an equal memory module in each slot.
I should point out this listing is a bit dated as this series can support 8 GB modules so you can go up to 16 GB of RAM.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thansk! So just to be clear, this is the 1.5v 'normal' DDR3? :)
DDR3L is a dual voltage capable memory DIMM, which supports operation at both 1.5V and 1.35V. DDR3L is also pin-compatible with DDR3.
DDR3 is a single voltage capable memory DIMM, which supports 1.5V operation only.
Basically you can use either but the older DDR3 is cheaper.
Thanks a lot!
Update: Time marches on ... Today finding older DDR3 is difficult and besides the price of DDR3L RAM has dropped and is often cheaper!
댓글 달기
I would not agree that the best answer is to consult Apple, since Apple is famous for not letting ppl know, how their devices actually work. You see that already in the short portion, Dan posted here:
The Maximum memory capacity of these machines is NOT 8 GB. 16 GB works just fine, Apple just never tested it so they never shared this information.
As for DDR3L and DDR3:
I also was not sure, so I tested it:
Both work without a problem, so you can install both.
As for, if it makes a difference: The Power Rail for the RAM is called "PP1V5S3_DDR", stating it as a 1.5 V rail. I installed DDR3L modules and still the voltage on the rail was 1.506 V. So even though the modules could run on 1.35 V, the logic board always runs them on 1.5 V since that is what it's designed for. This was tested with the most recent Catalina update, so with the most recent EFI.
This is not rocket since, but I could not find this definitive answer anywhere on the web, so I checked for myself and posted it here.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
@danj It can run 16gb Max Ram too
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
While some systems can support this much memory the thrust of the Q was on the differences between DDR3 & DDR3L.
댓글 달기
so besides the voltage does the older high 1.5v make it better or running a lower ddr3l make the MB run better and faster?
Also does cl 11 mean anything in terms of fastness and cycle time 1.875??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 22
전체 시간: 18,021
