주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Battery did not charge, battery ondicator off, but it power up!
I have problem with my mbp 2011
Simptoms:
battery don`t charge
battery indicators off
magsafe only green
in osx it says: no battery available
if i unpluged the magsafe it goes to sleep mode.
Any ideas ?
Update (10/11/2016)
By the way, i used apple test hardware and the result are OK! I don`t find any issues. :(
Update (10/11/2016)
I have tried with a new battery but is the same issue, i have this problem after i change the thermal pasta of cpu. My question is: Mbp can run normal without battery indicator ? Or it won`t charge without this indicator cable connected ?
Thanks for answares guys !
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Do you mean the indicator light is not working or the indicator in the top right corner?
댓글 달기
답변 3개
가장 유용한 답변
Battery issues more often than not are caused by a bad battery. Replace the battery with one that you know is good, and that will tell you the answer -- if it works, the battery was bad, and if it doesn't, you know it's the computer, and we can proceed further at that point.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
your battery might of reached the end of its lifespan. rechargeable batteries have a limited amount of charge/discharge cycles
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sandrinilea 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 10
전체 시간: 118
