주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Why does my phone turn on but wont charge (iPhone 5s)
I have just replaced the casing on my iPhone 5s, everything else works but the lighting port. When I turn the phone off and then plug it in it will turn on but when it turns on it wont charge. I tried cleaning out the port as well as using different cables. Please help me come up with a solution.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
They are reletively easy to change out btw
댓글 달기
답변 2개
선택된 답변
Replace the lightning flex by @benjamen50
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I am sorry I miss read that i though it was the other way around, i though it was not holding a charge. Sorry
댓글 달기
가장 유용한 답변
It sounds like a bad battery. It sounds like it would need replacement. I have the same problem with my 5s, I replaced the battery and it was working as new again.
Edit:
This looks like the battery you would need:
iPhone 5s Battery
iPhone 5s Battery 이미지
상품
iPhone 5s Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I had just replaced the battery could it be the lightning flex?
I used a ifixit replacement
I doubt its the battery because if it is not showing charging when its turned on then it must be the charging dock ribbon cable assembly gone faulty.
Most likely the ribbon cable suffered some damage from tearing when it was pryed out of the old iphone housing.
ok @benjamen50 I bought the ribbon cable
댓글 달기
귀하의 답변을 추가하세요
Robert Hayek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 69
