주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20012 질문 전체 보기
Why does my SSD crash my computer
Hi there fellow humans,
I recently installed a SSD (internally) as a startup disk in my Mac Pro (Early 2009). Unfortunately it often crashes - at random times - and the only way to get my computer functioning again is to hold down the power button. This problem even happens when I go back to using my old hard drive as the Startup Disk.
The SSD is a Mercury Electra 3G 480GB drive from OWC.
I'm rather perplexed...
Any suggestions would be greatly appreciated!
Ta,
Seb
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Well it shouldn't. I'm running a 512 SSD in mine with no issues. How was it formatted? Do you have a secondary standard boot drive installed and does it crash when using that one? What operating system are you running? Was there an update or upgrade you've done recently?
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi Mayer,
Thanks for your response.
My SSD is formatted as Journaled, with a GUID Partition Map.
I recently upgraded my operating system from 10.8 to El Capitan (10.11.4), but I was having problems with the old OS X too.
I have a secondary startup disk (on my Mac's original hard drive) and the SSD crashes that too when it suddenly seems to eject itself.
I thought I may have had a faulty drive, but I tried another one (the same kind - Mercury Electra) and that one also disappears from view and crashes my system.
Any thoughts...?
Cheers,
Seb
Since it does it with the old drive, I don't think the issue is the drive. Are you getting a Kernel panic on your crash? Have you changed the RAM configuration?
FYI - if your get the problem solved and want to go to Sierra, here's how I did it: EFI and Firmware update from 4,1 to 5,1 for Sierra Upgrade Solved
댓글 달기
I have an external SSD and had a similar problem. I noticed that when I checked Activity Monitor it always said "0 bytes" next to "Swap used". This was causing my Mac to run out of RAM very easily then freeze or crash.
This solution worked for me:
https://discussions.apple.com/thread/278...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Seb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 3,657
