주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
MacBook Core Duo (2 of them) won't boot at all
So I found some old MacBook Core Duos laying around, and I thought I'd convert them into CloudReady "Chromebooks"
After installing CloudReady (without rEFIt) on one of them, and booting to Kubuntu using a special EFI software on the other one, both of them do not sound a startup chime, even though both laptops' hard drives, CD slots, and fans are running.
I tried the "place your laptop under a lot of blankets and pillows" trick, and let one run for 80 minutes, and that didn't help the cause. I can't seem to determine what's causing the issue.
On the other hand, a black MacBook Core Duo from 2006, with a Core Duo I remind you, without rEFIt, installed the software perfectly, without a single hitch. It boots into CloudReady perfectly.
I've tried many steps to troubleshoot the two, including RAM resets, hard drive resets, PRAM/SMC resets, whatever I can. I'd extremely doubt this is a logic board problem, since they just stop working after booting/installing a different OS.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
These are generally plagued by the defective nVidia 8600 GPU. There was a class action law suit on them. Doing a reflow by putting them under blankets is like putting a bandaid on a gun shot wound.
Use a hot air rework station and reflow the GPU.
https://www.consumeraffairs.com/news04/2...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Don't have a hot air rework station at the moment, and for this one small project, I don't find it super valuable to get one. Any other DIY alternatives for something like this?
Not really. I have a stack of them I have not had time to get to yet. Not a lot of demand for these. Takes more time and effort to repair them, upgrade them than they're worth. You can get something like this for pretty cheap ($54) on eBay 853D SMD Hot Air Iron Gun Rework Soldering Station Welder
댓글 달기
가장 유용한 답변
Did you try a different HD? Had similar issue solved it by replacing th Hard Drive with a new one...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Haven't tried that yet, and I will once I get the chance. Seems like it could be a Hard Drive issue.
댓글 달기
귀하의 답변을 추가하세요
o355 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 234
