주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
iPod Classic content missing
Hello, My Ipod Classic is now not showing any playlists, songs, albums etc. It is just showing "No Playlists" "No Songs" "No albums" etc. I previously had dozens of playlists installed and thousands of songs but now I am getting the "No playlists" "No Songs" etc. So it is acting like all the content of the Ipod has been completely erased or deleted, however when I go into "settings" It shows me that there is 73 GB of spaced used out of 160.. so it appears the playlists and songs are still on the device however I can't get them to appear. Can you help and advise? Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
@ipodclassic does iTunes still recognize your iPod? What does iTunes tell you about the contents?
댓글 달기
답변 2개
가장 유용한 답변
Try a quick restore:
  1. Slide the Hold switch to the locked position and then slide it to unlocked again.
  2. Press and hold the Menu and Center (or Select) buttons together until you see the Apple logo (about six to eight seconds). You might need to repeat this step.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Quick restore is useless... everything is in ipod, but it all became invisible for ipod. Do you have any another solution of this problem?
Brilliant so easy, my wife very happy that her music has been recovered.
댓글 달기
Sounds like a software problem. This can probably be fixed with a restore. Plug your iPod into iTunes, then press “Restore”. This will erase your iPod and then put a new copy of the iPod software on it, making it the same as it was when you got it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
iTunes does not see the iPod. Any other way to "restore"?
댓글 달기
귀하의 답변을 추가하세요
Ipod Classic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 24
30일 전: 71
전체 시간: 4,250
