주요 콘텐츠로 건너뛰기
Sony Cyber-shot DSC-W5 5.1 Megapixel
10 질문 전체 보기
How to replace the cracked Battery/memory compartment cover?
I have a crack in the cover of the battery/memory stick compartment. It makes the camera think the batteries or low or dead or the memory stick isn't inserted correctly. I have replaced the batteries and it still tells me low or no battery. It will also just suddenly shut off. Took it to my reunion and kept trying to put pressure on it so it would stay in contact with batteries & stick. Was a real pain. Sometimes that worked, sometimes NOT. Please help thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Yow, I really hate it when the battery door cracks. It is the weakest link in EVERY camera I own.
Luckily there is a simple solution for this particular model.
Get a tripod with a quick release top. Some are less than $25 USD at big box stores.
Firmly attach the quick release top onto the camera bottom.
You can put a piece of cereal box cardboard between the battery door and the quick release plate to add extra pressure.
This usually holds the battery door closed and the camera works.
And you can quickly snap the camera into the tripod as an added bonus.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
+ I like it. Nice hack!
very helpful, many thanks.
댓글 달기
귀하의 답변을 추가하세요
Marian Brooks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 2,921
