주요 콘텐츠로 건너뛰기
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 질문 전체 보기
Can I solder broken wire back on using the old solder blob?
Hi! My headphones broke on one side. I can see the broken wire inside the ear cup and was wondering if I could just melt the solder that's there and push the wire back in. (after snipping the wire). I've never soldered before and don't know much about electronics.
Here's a picture, you can see where the wire's all broken.
https://postimg.org/image/6fcajabhl/
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Christian, as Shelton stated could be possible, but if you want a good clean trouble free repair at least get a little flux/rosin cored solder so you will have a clean soldered connection, saves from having to do it twice.
A small amount of rosin core solder can be purchased at most electronics stores and big box stores as well.
Below I will post a tutorial on soldering. Good luck.
https://www.youtube.com/watch?v=Qps9woUG...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Should be possible, your picture isn't the clearest though. Before of your temp when soldering you don't want to melt anything. Maybe watch a few basic videos on youtube before you try.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Christian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 3,241
