주요 콘텐츠로 건너뛰기
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
My Kenmore 110 Series washing machine won't start
My Kenmore model 110 series washing machine will not start. When i power it on and try to start it the machine makes a loud buzzing sound and doesn't start up.
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
arcadiafilm, Motor does not start, but makes a buzzing noise then it may be faulty. To check motor, remove the drive/pump belts and try to start the motor. If direct drive model, disengage the pump/direct drive coupling at transmission, if the motor starts, problem is with the transmission or pump and which can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced. Some times the pumps will accumulate debri or piece of small clothing wrapping around pumps propeller stopping motor from spinning. If you do not feel comfortable working on machine have a good repair Tech. have a look, diagnose and estimate repair. Check the attached links,instruction and guides, Good luck.
http://www.partselect.com/Repair/Washer/...
Kenmore 110 Series Washing Machine Drive Belt Replacement
Kenmore 110 Series Washing Machine Water Pump Replacement
Kenmore 110 Series Washing Machine Water Pump 이미지
안내서
난이도:
조정
15 - 30 minutes
Kenmore 110 Series Washing Machine Drive Belt 이미지
안내서
난이도:
조정
15 - 30 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I just replaced the lid lock switch on my Kenmore 110 washing and it won’t start now. It is like there is no power going to it. I have checked the and there is power going to where I plug it in, so that isn’t the problem. Can you give me another idea as to why it wouldn’t turn on?
댓글 달기
답변을 추가하세요
arcadiafilm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 1,803
