주요 콘텐츠로 건너뛰기
The 8.9" version of Amazon's new high-end tablet series, released in November, 2013.
Restarting continously over and over to Logo
I downloaded a new app and my HDX turned itself off and started a cycle of restarting that will not stop. Did a number of factory resets, no change. It restarts only to the colored logo and shuts off and restarts over and over. Amazon said that it needs to be replaced. Can it be repaired?
Also I have left it on the charger overnight before the last factory reset and it makes no difference.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개:
This started on mine tonight after support said to Reset to Factory Defaults. I loved my HDX!
I was reading a book when this happened to me, page just locked up, did 40 hold thing then HDX in logo boot up loop, spend hours on chat with Amazon, finally they told me to replace it. I did but if I can fix my HDX I will and like you I really love it. Requested HD from here, hope it has OS then I will try and fix mine.
댓글 달기
답변 2개
Hi!
You're gonna have to boot to recovery mode in case of a boot loop.
While it's off, hold the power key and volume up.
You will be prompted to Recovery mode. Use volume to scroll and power to select.
Try wiping cache partition. Then reboot.
If that doesn't work, try the same steps, but instead factory reset.
If that doesn't work, then you should definitely get a replacement.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had this problem, so I prised it apart expecting to remove/renew the battery. Inside I discovered the works were retained by 8 tiny steel screws. To keep these safe I decided to store them, on a strong magnet. Starting at the bottom right corner as I brought the magnet to the screw the Kindle immediately stopped malfunctioning. I tested all operations and everyone worked properly and without the sluggishness which had developed over the previous year!! Try this method without prising apart. Start at 4 ( of the clock) and move anti-clockwise. Share the result!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Darrel Plimpton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 51
전체 시간: 11,833
