What do I do if my device will not suck anything up?
I have plugged in and turned on my vacuum but it won't pick up any dirt particles. What should I do?
좋은 질문 입니까?
좋은 질문 입니까?
If your device is turned on but won’t suck anything up, try emptying your dust cap of any debris or replacing it if it is very old. Also check to see if there’s is any build up in the vacuum tube by turning off the device and checking with a flashlight. If the problem persists you may have a tear in your vacuum hole so yo may need to replace it.
해당 답변은 도움이 되었습니까?
Cause 1
Air Filter
The air filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 2
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Cause 3
Vacuum Hose
Remove the hose from the vacuum cleaner, stretch out the hose so that it is straight, shine a bright flashlight into one end of the hose, and look through the opposite end of the hose. If the flashlight beam is not visible from the other end of the vacuum hose, this indicates that the vacuum hose is clogged or obstructed.
해당 답변은 도움이 되었습니까?
@mayer student, student
OK, I miss them too, they gave a pretty good answer ;-)
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 239
