Why does my turn signal oonly work on one side?
Turn signal works normal on left side, but it blinks rapidly on right side and only the front light blinks.
좋은 질문 입니까?
좋은 질문 입니까?
Hi Dennis,
A rapidly blinking turn signal often means that the light bulb is about to burn out. Try replacing the bulbs and see if that fixes your problem. This video might help with the replacement: https://www.youtube.com/watch?v=c0Rk3kh2...
Good luck,
Paige
해당 답변은 도움이 되었습니까?
You need a new Turn Signal Switch, relatively cheap part
해당 답변은 도움이 되었습니까?
Bulb replacement solved the problem
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 132
댓글 1개
Bulb replacement worked. Thank you
Dennis Johnson 의
